Hi. Wondered if anyone could help. When using the latest Zadig (2.7 build 765) in Windows 11, the driver certificate fails, when trying to replace the existing driver (STTub30 (v3.0.4.0) with the WinUSB driver (v6.1.7600.16385). Do i need to find a Windows 10 laptop or is there a workaround (eg could I deploy from a hyper-v win 10 vm for example)
Log
libwdi:debug [syslog] kage import failed for device.
libwdi:debug [syslog] ndv: {Update Device Driver - exit(00000109)}
libwdi:debug [syslog] !!! ndv: Failed to install device instance ‘USB\VID_8087&PID_0A2A\5&2F0C36E4&0&7’. Error = 0x00000109
libwdi:debug [syslog] ! ndv: Failed to install device instance ‘USB\VID_8087&PID_0A2A\5&2F0C36E4&0&7’. Error = 0x00000109
libwdi:debug [process_message] Switching timeout back to finite
libwdi:debug [installer process] This version of Windows is refusing to trust the installed certificate.
libwdi:debug [process_message] Installer process completed
Driver Installation: FAILED (Operation not supported or not implemented)
