Wilderness Network example errors
Using Netduino 3 Wifi. I have copied the Network example code into Visual Studio Community 2015 and there are many errors.
Does anyone have a network example that will compile without error?
Hi Ronald,
What errors are you getting?
Have you checked out this getting started guide? Try to follow it and report back.
Thanks,
Jorge
Thank you for your reply. I found out that I was missing some of the required library’s and then it compiled without error.
Before I deployed it, my Netduino 3 WiFi was showing the green showing the WiFi was active.
After I deployed the example code the green led was not lit and both the white leds were on, so I guess it was locked up.
I had to reset it to use my old test program.
Any ideas why the code would not deploy correctly?&
