VS2017 and NETMF 4.3 - A Hack
Like many, I have been looking for VS 2017 support for Netduino and recently I came across an article discussing how to get NETMF 4.3 working with VS 2017. Now this is a bit of a hack but it seems to work.
Overview:
  • Install NETMF 4.4 (installers on the page linked above)
  • Install the VS 2017 add-in (installer on the page above)
  • Copy the NETMF 4.3 into the VS 2017 MSBuild file structure (instructions at the end of post above)
For the last step I had to copy all of the directories (except 4.4) in C:\Program Files (x86)\Microsoft .NET Micro Framework to the directory C:\Program Files (x86)\MSBuild\Microsoft\.NET Micro Framework
At the moment this is unsupported and provided as information for those who wish to try and get NETMF working with VS 2017. I’ve been using this configuration for the last 1-2 weeks.
Hope this help,
Hi Mark
Thanks for taking the time to post this information. As soon as i’m back in the office I’ll give it a try and feedback how it went. This would mean that I can get rid of my VS2015 install at last and just use VS2017.
Jason
ā€œAt the moment this is unsupported and provided as information for those who wish to try and get NETMF working with VS 2017ā€ --Nevyn
We started with a similar method when we researched VS2017 support for our NETMF 4.4 HERO robot control board. So the procedure is sound.
Though ultimately we forked and modified netmf-interpreter to produce a VSIX that natively works in VS2017 and our compiled NETMF4.4 stack.
http://informatix.miloush.net/microframework/Articles/VS2017SDK.aspx
Hi all,
First; thanks to take the time to build and share this solution.
I gave it a try and some codes worked ok but others I have got strange errors.
(I know this is still unsupported, but I thought; it may exist a simple solution…);
The errors are pointing to System.Collections.Generic which by rights, isn’t supportet by .netmf.
Here are the error messages:
Error CS0518 Predefined type ā€˜System.Collections.Generic.IEnumerator`1’ is not defined or imported
Error CS0656 Missing compiler required member 'System.Collections.Generic.IEnumerator`1.Current’
and here is the method where it is happening:
public IEnumerator GetEnumerator()
    for (int i = 0; i < this._ItemCount; i++)
        yield return this._people[i];
If I change the target framework to version 4.4, it compiles beautifully :slight_smile:
Note: The actual project was done on vs2012 using .netmf 4.3 and netduino plus 2 and is working perfectly.
