So, what is the answer? When can we expect VS Code support?
I just bought a brick because I can’t for the life of me get the stinking ST Driver to install and show up in device mgr.
I even wiped my Dell laptop and re-installed Win 10 trying to get my meadow development going.
You promised!
Please, just give us a hint.
I am using VS Code on Ubuntu but it requires the use of the command line interface.
What I do is:
Create new project with dotnet new console -f net5.0 -o ProjectName (make sure that you have installed the latest dotnet-core SDK)
add the Meadow dependencies with the dotnet CLI command dotnet add package from nuget Meadow and Meadow.Foundation. You then should find those dependencies in the .csproj file in the ItemGroup
The next step is to change the Framework to net4.8 in the .csproj file and run dotnet restore after changing it.
You then can proceed with the code from the Hello World example
To build the project run dotnet msbuild ProjectName.csproj
Upload the files from the build directory to the Meadow using the Meadow CLI
I recommend to install the C# Extension of Microsoft from the Marketplace.
