Unable to perform http request using Maple
Hi
I have the F7V2 hack kit, and decided to start with this Led sample
I can see in the logs from Meadow that the Maple server was created ok and it is broadcasting ok as well.
So in the Maui app I can see how the Maple server is recognized and after that when performing an HTTP request it fails, and return false, then I decompile and just create the HttpClient the same way the Maple client does, and the exception is the following: Failed to connect to /192.168.1.59:5417 ---> Java.Net.ConnectException: Failed to connect to /192.168.1.59:5417
Regards
There is on endpoint at /192.168.1.59:5417
try something with method such as /192.168.1.59:5417/turnon
