I am attempting to run the HelloMeadow project (right from the Template) on a new Meadow device, but the first Deployment I get the following error, then following deployments get stuck on “Loading Application…”. I can’t find any errors or logs. All the latest versions of everything used (VS, Meadow, Nuget, etc) have been loaded.
2>------ Deploy started: Project: HelloMeadow, Configuration: Release Any CPU ------
2>[12/22/2020 4:26:00 PM] Deploying to Meadow on COM4…
2>[12/22/2020 4:26:08 PM] Checking files on device (may take several seconds) (00:00:07.9610759 since last.)
2>[12/22/2020 4:26:18 PM] Found App.exe (00:00:09.6365277 since last.)
2>[12/22/2020 4:26:18 PM] Found mscorlib.dll (00:00:00.0000501 since last.)
2>[12/22/2020 4:26:18 PM] Found Meadow.dll (00:00:00.0000370 since last.)
2>[12/22/2020 4:26:18 PM] Found System.dll (00:00:00.0000197 since last.)
2>[12/22/2020 4:26:18 PM] Found Mono.Security.dll (00:00:00.0000347 since last.)
2>[12/22/2020 4:26:18 PM] Found System.Configuration.dll (00:00:00.0000275 since last.)
2>[12/22/2020 4:26:18 PM] Found System.Xml.dll (00:00:00.0000230 since last.)
2>[12/22/2020 4:26:18 PM] Found System.Security.dll (00:00:00.0000202 since last.)
2>[12/22/2020 4:26:18 PM] Found System.Core.dll (00:00:00.0000154 since last.)
2>[12/22/2020 4:26:18 PM] Found System.Numerics.dll (00:00:00.0000197 since last.)
2>[12/22/2020 4:26:18 PM] Found Meadow.Foundation.dll (00:00:00.0000192 since last.)
2>Exception of type ‘MeadowCLI.DeviceManagement.MeadowDeviceManagerException’ was thrown.
