I don’t see this on the road map in the documentation, nor can I find anything in the forums (except another unanswered question about it.) Maybe I’m just blind.
I saw on the hardware page there is an image of a development board with an SD cards lot on it (Hardware). I assume there are plans for supporting an SD card with the file system operations under System.IO based on that image.
Is there anyway you could put that feature up on the road map in order to provide some transparency?
