lytz
May 17, 2022, 5:03pm
1
When running the dotnet tool install WildernessLabs.Meadow.CLI --global command, I’m getting
> Unhandled exception: Microsoft.NET.HostModel.AppHost.AppHostSigningException: /Users/victorli/.dotnet/tools/meadow: code object is not signed at all
> In architecture: x86_64
How do I proceed? Thanx.
Hi @lytz What version of Meadow and version of MacOS are you using?
lytz
May 18, 2022, 7:46pm
3
Big Sur 11.3.1
I didn’t get to the step of downloading MeadowOS yet as I’m stuck on installing the Cli
Following this guide Getting Started w/ Meadow by Controlling the Onboard RGB LED - Hackster.io
I’m running Big Sur 11.6.5 am not seeing this issue.
Could you please run
dotnet --version
And let me know which version of dotnet you have
Could you also confirm which type of Mac hardware you are running this on, to see if someone in the office has something similar?
lytz
May 18, 2022, 8:33pm
6
6.0.300 is my dotnet version
lytz
May 18, 2022, 8:34pm
7
MacBook Pro (15-inch, 2018)
I’ll be honest and say we’ve not had anyone hit a signing issue.
It definitely shouldn’t be needed, but could you please try
sudo dotnet tool install WildernessLabs.Meadow.CLI --global
