Have you seen a successful RS-485 communication to your Netduino?
Which module/shield did you use?
The ones I’m considering:
Yourduino provided module Linksprite Sparkfun
All seem to use the same chip though.
I think I read through all 485 posts in the old forum. Concluding it is not easy to get my Netduino 3 connected.
Any common pitfalls to avoid or basic steps to start from?
Thanks.
Raido
Appreciate the blog post and nice work done there!
Unfortunately I can’t use ethernet-rs485 converter as my application needs ip network too.
Please update this post if you happen hear about a successful implementation of rs485 over Netduino io ports.
Thanks.
Yes, I guess my conclusion reading the old forum - that it does not work - was just wrong.
Probably all of the components I linked in the original post would do just fine. Will try.
Thanks a ton!
