sing System;
using System.Net;
using System.Net.Sockets;
using Microsoft.SPOT;
using SecretLabs.NETMF.IO;
using System.IO;
using System.Collections;
namespace NetduinoApplication9
public class Program
public static void Main()
public class CIni
public CIni()
_Sections = new Hashtable();
/// <summary>
/// Loads the Reads the data in the ini file into the IniFile object
/// </summary>
/// <param name="filename"></param>
public void Load(string FileName, bool append)
if (!append)
DeleteSections();
string Section = "";
string[] keyvaluepair;
FileStream inFileStream = new FileStream(Path.Combine("\\SD", FileName), FileMode.Open);
using (StreamReader inStreamReader = new StreamReader(inFileStream))
string[] lines = inStreamReader.ReadToEnd().ToLower().Split(new char[] { '\n', '\r' });
foreach (string line in lines)
if (line == string.Empty)
continue;
if (';' == line[0])
continue;
if ('[' == line[0] && ']' == line[line.Length - 1])
Section = line.Substring(1, line.Length - 2);
else if (-1 != line.IndexOf("="))
keyvaluepair = line.Split(new char[] { '=' });
SetValue(Section, keyvaluepair[0], keyvaluepair[1]);
inStreamReader.Close();
inFileStream.Close();
/// <summary>
/// Used to save the data back to the file or your choice
/// </summary>
/// <param name="FileName"></param>
public void Save(string FileName)
using (FileStream outFileStream = new FileStream(Path.Combine("\\SD", FileName), FileMode.Create))
using (StreamWriter outStreamWriter = new StreamWriter(outFileStream))
foreach (object Sections in _Sections.Keys)
outStreamWriter.WriteLine("[" + Sections.ToString() + "]");
Hashtable keyvalpair = (Hashtable)_Sections[Sections];
foreach (object key in keyvalpair.Keys)
outStreamWriter.WriteLine(key.ToString() + "=" + keyvalpair[key].ToString());
outStreamWriter.Close();
outFileStream.Close();
public string GetValue(string Section, string key, string defkey = "")
key = key.ToLower();
Section = Section.ToLower();
Hashtable keyvalpair = (Hashtable)_Sections[Section];
if ((null != keyvalpair) && (keyvalpair.Contains(key)))
defkey = keyvalpair[key].ToString();
return defkey;
public float GetValue(string Section, string key, float defkey)
try { defkey = (float)double.Parse(GetValue(Section, key, defkey.ToString())); }
catch (Exception) { }
return defkey;
public double GetValue(string Section, string key, double defkey)
try { defkey = double.Parse(GetValue(Section, key, defkey.ToString())); }
return defkey;
public UInt64 GetValue(string Section, string key, UInt64 defkey)
try { defkey = UInt64.Parse(GetValue(Section, key, defkey.ToString())); }
return defkey;
public UInt32 GetValue(string Section, string key, UInt32 defkey)
try { defkey = UInt32.Parse(GetValue(Section, key, defkey.ToString())); }
return defkey;
public UInt16 GetValue(string Section, string key, UInt16 defkey)
try { defkey = UInt16.Parse(GetValue(Section, key, defkey.ToString())); }
return defkey;
public byte GetValue(string Section, string key, byte defkey)
try { defkey = byte.Parse(GetValue(Section, key, defkey.ToString())); }
return defkey;
public Int64 GetValue(string Section, string key, Int64 defkey)
try { defkey = Int64.Parse(GetValue(Section, key, defkey.ToString())); }
return defkey;
public Int32 GetValue(string Section, string key, Int32 defkey)
try { defkey = Int32.Parse(GetValue(Section, key, defkey.ToString())); }
return defkey;
public Int16 GetValue(string Section, string key, Int16 defkey)
try { defkey = Int16.Parse(GetValue(Section, key, defkey.ToString())); }
return defkey;
public void SetValue(string Section, string key, string value)
if (!_Sections.Contains(Section))
_Sections.Add(Section, new Hashtable());
if (keyvalpair.Contains(key))
keyvalpair[key] = value;
else
keyvalpair.Add(key, value);
public void SetValue(string Section, string key, float value)
SetValue(Section, key, value.ToString());
public void SetValue(string Section, string key, double value)
public void SetValue(string Section, string key, byte value)
public void SetValue(string Section, string key, Int16 value)
public void SetValue(string Section, string key, Int32 value)
public void SetValue(string Section, string key, Int64 value)
public void SetValue(string Section, string key, char value)
public void SetValue(string Section, string key, UInt16 value)
public void SetValue(string Section, string key, UInt32 value)
public void SetValue(string Section, string key, UInt64 value)
public void DeleteSection(string Section)
if (_Sections.Contains(Section))
_Sections.Remove(Section);
public void DeleteSections()
_Sections.Clear();
private Hashtable _Sections = null;
