Hi there,
My name is Simo from Morocco,
I would like to develop o project on Netduino 3 ethernet and be able to count pulses from a rain gauge and read water level from a 4-20mA sensor and store them on sd-card (datalogger),
Next step is to send this data to a mysql server over the internet,
could you please direct me where to start,
Best regards
Hi
To count pulses in a period and upload the count to an HTTP endpoint you could adapt my Xively connected heart rate monitor.
It uses an interrupt port and a timer to do the counting, and an HttpWebRequest to post the data to an endpoint.
There in no longer a free version of Xively but Adafruit.IO is really robust and reliable (has a free version as well)
Adafruit.IO could get you up an running faster than a DIY backend.
With the MicroSD make sure you flush after write so reduce scope for corrupted files. I usually write file to a temp directory then move to long-term storage directory as last step.
string message = new String(Encoding.UTF8.GetChars(data));
Debug.Print("+" + DateTime.UtcNow.ToString("HH:mm:ss") + " L=" + data.Length + " M=" + message);
string filename = DateTime.UtcNow.ToString("yyyyMMddhhmmssff") + ".txt";
string tempDirectory = Path.Combine("\\sd", "temp");
string tempFilePath = Path.Combine(tempDirectory, filename);
string queueDirectory = Path.Combine("\\sd", "data");
string queueFilePath = Path.Combine(queueDirectory, filename);
File.WriteAllBytes(tempFilePath, data);
File.Move(tempFilePath, queueFilePath);
new Microsoft.SPOT.IO.VolumeInfo("\\sd").FlushAll();
What’s the 4-20mA sensor? I have found 4-20mA to I2C or similar convertors can be expensive.
@KiwiBryn
blog.devmobile.co.nz
