I’m trying to drive a solenoid after motion has started, problem is whenever event handler fires function is runs it 3 times every time…why is this?
I only need the function run once per OnMotionStart event.
Any help on this??
Ill drop the relevant code below:
public class App
//Initialize output pins for water valves
OutputPort out1 = new OutputPort(Pins.GPIO_PIN_D0, false);
OutputPort out2 = new OutputPort(Pins.GPIO_PIN_D1, false);
OutputPort outIR = new OutputPort(Pins.GPIO_PIN_D2, false);
OutputPort out3 = new OutputPort(Pins.GPIO_PIN_D3, false);
OutputPort out4 = new OutputPort(Pins.GPIO_PIN_D4, false);
//Initialize HBridge for first two water valves
//HBridgeMotor valve1 = new HBridgeMotor(PWMChannels.PWM_PIN_D5, PWMChannels.PWM_PIN_D6, Pins.GPIO_PIN_D7);
public App()
InitializePeripherals();
public void InitializePeripherals()
//setting up all the sensors with event handlers
ParallaxPIR motion1 = new ParallaxPIR(Pins.GPIO_PIN_A0);
ParallaxPIR motion2 = new ParallaxPIR(Pins.GPIO_PIN_A1);
ParallaxPIR motionIR = new ParallaxPIR(Pins.GPIO_PIN_A2);
ParallaxPIR motion3 = new ParallaxPIR(Pins.GPIO_PIN_A3);
ParallaxPIR motion4 = new ParallaxPIR(Pins.GPIO_PIN_A4);
//valve1.IsNeutral = true;
motion1.OnMotionStart += Motion1_OnMotionStart;
motion1.OnMotionEnd += Motion1_OnMotionEnd;
motion2.OnMotionStart += Motion2_OnMotionStart;
motion2.OnMotionEnd += Motion2_OnMotionEnd;
motion3.OnMotionStart += Motion3_OnMotionStart;
motion3.OnMotionEnd += Motion3_OnMotionEnd;
motion4.OnMotionStart += Motion4_OnMotionStart;
motion4.OnMotionEnd += Motion4_OnMotionEnd;
motionIR.OnMotionStart += MotionIR_OnMotionStart;
motionIR.OnMotionEnd += MotionIR_OnMotionEnd;
//Thread.Sleep(Timeout.Infinite);
private void ToggleValve4()
Thread.Sleep(50);
out3.Write(true); //open valve for 50 ms
Thread.Sleep(50);
out3.Write(false); //finish on pulse
Thread.Sleep(2000); //let valve stay open for 2 seconds
out4.Write(true); //off pulse
Thread.Sleep(50);
out4.Write(false);
private void MotionIR_OnMotionEnd(object sender)
outIR.Write(false);
Debug.Print("MotionIR..................motion");
//throw new NotImplementedException();
private void MotionIR_OnMotionStart(object sender)
ToggleValve4();
public void Run()
