I was originally running Visual Studio 2017 for another project, so that’s installed (just an fyi in case it may cause interference), but then I got the Netduino 3 with ethernet.
Following the instructions and browsing online lead me to download Visual Studio 2015, and run all the setup steps here: http://developer.wildernesslabs.co/Netduino/Getting_Started/Installation/Windows/
.NET Micro Framework (.NETMF) v4.3.2 - QFE2 SDK
NETMF Plugin for Visual Studio Visual Studio 2015
Netduino SDK
Once run, I went back to following the ‘Getting Started’ steps (http://developer.wildernesslabs.co/Netduino/Getting_Started/) but when making a new project with micro framework I only have the options of class library, console application and windows application.
Assuming the Console Application would work, I selected it and moved on.
Under references I only have Analyzers and Microsoft.SPOT.Native, and have no idea where to guide the ‘Add Reference’ to in order to find:
Microsoft.Spot.Hardware
SecretLabs.NETMF.Hardware
SecretLabs.NETMF.Harware.Netduino
I’ve also tried opening the project created by doing all of this, but it says the project is targeting “.NetMicroFramework,Version=v4.4” which is not installed on this machine.
Have I managed to mess up before even starting?
Any help as to where to get these files, how to fix the issues, etc. would be greatly appreciated!
