Hi there. I’m totally new to netduino plus. I’ve purchased this board and after following instructions and installing required development environments including:
Visual Studio Express 2010
NETMF SDK 4.2
Netduino SDK 4.2.2.0 32 bit or 64 bit
I get this error message:
Cannot deploy the base assembly ‘mscorlib’,or any of his satellite assemblies,to device -USB :NetduinoPlus twice. Assembly ‘mscorlib’ on the device has version 4.1.2821.0, while the program is trying to deploy version 4.2.0.0
I have more or less the same problem, I mean, I have Visual Studio 2010 installed and .Net Microframework 4.2. Recently I purchase tree new Netduino Plus 2 with version 4.3.1.0 and my application was developed with 4.2 so when i try to deploy obtain the same message. I would like to downgrade 4.3.1.0 to 4.2, its possible? I cant find application that Cris suggested on other topics.
A version of the 4.2.2 firmware is available on the Secretlabs forums. This details what you would need to do to install a 4.2.2 firmware on the Netduino Plus 2.
The ST DfuSe Demonstrator 3.0.5 is available from ST. It looks like the zip file has the tester application in there as well.
I have some problem, when I do connect my Netduino Plus 2 board to PC via USB cable its not showing in the MFDeploy tool.
I do select Device to USB, but in the selection box ny Netduino is not showing.
Is there any problem is comed in my device or there is any problem. Please help me out.
This retired dude is trying to d/l the legacy firmware to use on my original Netduino Plus modules (I have 2 of these to experiment with). The boards are currently running 4.1.0.6 firmware.
The download link you provide is not working due to bad certificate…
Here’s the site the link tries to take me to:
Not sure who amazonaws.com is… I’m still trying to get used to the switchover from the old Netduino.com forums. Is that the right place to get the firmware from (I should ignore the security alert?) or is there someplace else I can find what I need to update my boards? Thanks in advance.
