Greetings,
What are the overall dimensions of the N3 Ethernet? I have not come across it. Thank you.
J —
Greetings,
J —
3.2 inches x 2.1 inches (81mm x 53mm).
Thank you very much for the information. I just realized I could have used the PCB files to determine the dimensions.
J -
3D print models are here.
so if you’re doing enclosures or whatever, you can drop these right into your drawings.
