I’ve recently made my first real project with the N2+, it’s a multi remote temperature sensor.
I used existing open source libraries for xbee communication, JSON, web server, and customized them to my needs.
So I made a solution with multiple projects in it.
The problem arises when I deploy the complete solution, on project deploys I can see some strange lines containing:
Found Assembly ??????????????????????????????????????????????????????????????????????? Found Assembly ??????????????????????????????????????????????????????????????????????? Found Assembly ???????????????????????????????????????????????????????????????????????
Troubleshooting the case I manually deployed each of the project(s) which were giving me the lines but I couldn’t reproduce it. Manual deploy of the projects always looks the Ok, ie. no above lines.
The erratic lines only occur if I deploy the complete solution.
Thanks in advance for any hints.
Igor
