In an attempt to resolve some issues I was having with the Meadow’s WiFi, I uninstalled then reinstalled the Meadow VS Extensions, and rebooted my computer. Now, I get this error message every time VS 2019 starts:
I’ve done this twice now, and gotten the same result, so the issue is repeatable. Anyone now how to fix this?
Have you had any luck installing the extension? Seems like your local app data might be corrupted preventing you from re-installing it. I found this possible solution in stack overflow. Give that a try to those options but make sure to back up any files before deleting them in case you need to recover them.
