Hello,
Is there a library for the VL6180X sensor? I’ve noticed there’s one for the VL53L0X was wondering if anyone had developed one for this sensor.
If not, what if i convert a library from for example an arduino, will it work? ( using the meadow f7 libraries for communication and etc of course ).
I have not used this particular sensor. It would be cool if you created a library for it, for everyone to use.
There should be no reason to keep you from interfacing with it from an example on the Arduino.
I’ve tried to do it. It wouldnt even return the device id properly according to the datasheet, communication was not reliable at all, couldn’t get it to work even tho I pretty much “copy pasted” a library from arduino
