After a few months of not looking at Netduino and the issues I was seeing at that time. I saw that the 1 bug reported against Maple was fixed in the latest version 0.10.
However after downloading the latest Netduino.Foundation zip I built the project and see an error. I removed the code causing the error but before I get to deep I ask if this is an issue removing this?
Can anyone advise if this will cause other issues?
ApplianceHost.cs in RequestHandler
public RequestHandler(HttpListenerContext context) : base(context)
Severity Code Description Project File Line Suppression State
Error CS1729 ‘RequestHandlerBase’ does not contain a constructor that takes 1 arguments ApplianceHost C:\Users\brad\Downloads\Netduino_Samples-master\Connected_CoffeeMaker\ApplianceHost\src\ApplianceHost\RequestHandler.cs 13 Active
So by removing : base(context) I have a building project.
I have not tried to use this so I am hoping that this is an OK change or is there a reason for this error?
