There were some GPRS shields that were working with the Netduino (like the SeeedStudio), but they are discontinued now…
Does anyone now if Botletics SIM7000 LTE CAT-M1 NB-IoT Cellular GNSS would work with Netduino2+?
Or any other one?
I am particularly interested in the NB-IoT versions.
Looking at the schematic it appears that you should be able to use this if you adjust the logic level used on the board. There is a note on the schematic stating that board used 5V logic. To use the 3.3V logic it looks like you will need to do the following:
Cut the trace at JP4 to disconnect the 5V signal to TXB0104
Short the solder bridge connecting J7 to TXB0104
Connect 3.3V to pin 2 of J7
I’m not sure if the temperature sensor would work as the suggestion is that the sensor is using Vcc set to 5V.
This board is a little of overhead, as I (currently ) don’t need the GPS and temperature sensor only the NB-IoT connection, but I couldn’t find another shield with it on sale. Every other one I checked was out of stock discontinued and then I stumbled on this one.
I will go for this one, although it’s a bit of expensive, if I don’t find a simpler one.
It looks like I will have to wire it externally and not like a direct plugin to the netduino.
Not really what I was looking for but if that’s the only option…
Thanks Mark.
Here at LooUQ we are evaluating the interest and effort to support the Meadow with our LTEm1 IoT modem, which is NB-IOT capable but not yet NB-IOT certified here in the US.
There are many LTE sheilds that you can use for example Arduino MKR 1400 GSM or Pycom GPy or even Botletics SIM7000 Arduino Shield etc. I will suggest you to go for the Arduino MKR 1400 GSM as it is the best sheild among them. Make sure that it won’t get ERROR CODE 0XC0000428 as I have faced that.
