Is there a NETMF C# library available to assist with Lora P2P development, using the Dragino Lora Shield as radio link?
Here is a link to one shield available on the internet: https://www.iot-store.com.au/collections/iot-networking-comms/products/lora-shield-for-arduino-long-range-transceiver
I scoured the internet but could only find code for the RaspBerry Pi and Windows IoT Core. I think the Raspberry Pi is a bit too power hungry for most remote IoT applications, therefore my interest in using NetDuino.
Your help shall be much appreciated.
Regards
There isn’t one that I know of, but it shouldn’t be that difficult to port the Windows IoT Core driver to Netduino.
Can you post a link to the driver source?
Here is the link to the Windows IoT code:
You might be right, could be easy to port. Does not look as if make any use of generics, async/await and all those new C# features.
Regards
In retrospect, I had another look and the code does indeed use generics and the Task<> paradigm. Porting could be a bit tricky…
Yeah, I see that. But it looks like a lot of that library is actually to support some of their other boards. It might not be that much work getting a basic LoRa driver up.
True. I’ll have a look. Thanks for the feedback.
Hi
Just incase anyone lands here looking for a LoRa NetMF driver and misses my other post
NetMF
@KiwiBryn
blog.devmobile.co.nz
