I need some help getting the I2C communication working with my N3.
I’ve tried running a few devices over I2C with no luck.
The first device was an AM2320 Temp/Humidity sensor (adafruit.com/product/3721)
I was attempting to write my own drivers for this one. First I tried the examples from Wilderness labs using I2CDevice, but then after that didnt work I tried the foundation’s I2CBus, no luck there either.
All I end up with is a “WriteRead: Retry count exceeded” error. I ran into this error in the first attempt as well. I even hooked everything up to a second/spare N3 controller, same result.
Can anybody point me in the right direction or tell me what I am doing wrong?
I’m still trying to figure out how to toggle the internal pull-up resistors. I read about that in other I2C issues around the web, but still havent figured out how to control that internally.
I have a stripped back example of a couple of I2C device drivers on my blog…
Have a look at
This post has an example of a light-weight I2C temperature & humidity sensor (different model Silicon Labs device to yours but a reasonable starting point) including the port strobe on startup magic.
Hi…the problem I have is that I can only get the SparkFun module to work with the Netduino; I can’t get the Adafruit one to work. It fails when I try to do a Soft Reset.
I have been successful in getting both modules to work with an Arduino type MCU (Teensy 3.1), using the exact same code.
I read your comments with interest and have tried connecting VIn on the HTU21D-F to 5V rather than to 3.3V. It didn’t make a difference for me.
