I am doing a small project to read two analog data inputs and display their values on a LCD system. When I did them separately it worked well but I am confused as to how to combine the two codes so that the LCD will display the Temperature on Line 1 while the Voltage on Line 2. The codes I did are as follows. Please add comments when editing my comment since I really need to understand what I am doing as well as what each line of code executes in my program…
The codes are;
using System.Net;
using System.Net.Sockets;
using Microsoft.SPOT;
using SecretLabs.NETMF.Hardware.NetduinoPlus;
//using LCD;
namespace Voltage_Temperature_Reader
public class Program
public static void Main()
//Voltagemeter Codes to read and display voltage
Ulcd.Initialise(); //initialise the LCD
AnalogInput vin = new AnalogInput(Pins.GPIO_PIN_A0); //Analog input connect to A0
vin.SetRange(0, 1023); //Set Ananlog Digital Convertor range to go from 0 to 1023
double digit = 0.0; //This is the AD convertor output value
int fraction = 0;
int wholevalue = 0;
int integervalue = 0;
double volt = 0.0;
digit = vin.Read(); //read the ADC output
//V=mx+c
volt = (float)(0.06517 * digit * 100); //Relationship between ADC value and physicall signal being measured
wholevalue = (int)(System.Math.Round(volt)); //remove extra digits want only up to 4 digits
fraction = (wholevalue % 100); //pull out the fraction part of the value
integervalue = wholevalue / 100; //pull out the integer part of the value
Thread.Sleep(100);
Ulcd.ShowText(1, "VOLTAGE: = " + integervalue.ToString() + "." + fraction.ToString() + "V"); //send value to LCD for display
Debug.Print("VOLTAGE: = " + integervalue.ToString() + "." + fraction.ToString() + "V");
//Thermistor Codes to read and display temprature
AnalogInput pot = new AnalogInput(Pins.GPIO_PIN_A0); //connect input to pin #0 of NetDuino
pot.SetRange(0, 1023); //We want NetDuino values to vary between 0 qnd 1023...there is a 10bits ADC in the NetDuino.
int potvalue = 0; //store input values as potvalue
potvalue = pot.Read(); //read the analog inputs from the thermistor
double tempt = 127 * (System.Math.Pow(System.Math.E, -0.002 * potvalue)); //calculate temperature
int myval = (int)tempt; //convert temperature from double to int
string val = myval.ToString(); //convert temperature from int to string for display
//Debug.Print("NetDuino Value is: " + potvalue); //display NetDuino value
Debug.Print("Temperature = " + val + "oC"); //display calculated temperature
Thanks so much.
