Looking for a method to encode a URL but cannot find one. Can some point me in the right direction (NETMF 4.3).
I think that you will have to write your own (or find an implementation on the web). I have seen questions of this nature in the past and the developer has always provided their own implementation of this method.
Thanks Mark, that is what I ended up doing.
How do I insert a code snippet into the blog? Will supply the code I wrote in case its of help to anyone else.
Joe
Thank you being willing to share your work.
This site allows the use of markdown to format messages. Git has a Markdown guide which covers the basics. Scroll down the page and look for the Syntax Highlighting section. The language tag for C# is the three back ticks followed by the word csharp. Note that this is in lower case. Code should look like the following when formatted correctly.
int i = 0;
Thanks again Mark
In case anyone is interested here is the routine I wrote for the URL encoding. It does not cater for all the possible characters that need escaping but handled the ones I needed.
Note: Space can be replaced by either %20 or the + sign depending on whether its Url or Uri encoding. I have opted for + sign as I need to match what the TextEncoder.Encode() does in .Net Core 2.0.
/// <summary>
/// Simple URL encoder that replaces characters from URL and replaces with percentage escaped chars
/// </summary>
/// <param name="_input">Url to encode</param>
/// <returns>Encoded Url</returns>
public static string SimpleUrlEncode(string _input)
StringBuilder _encoded = new StringBuilder();
foreach( char _chr in _input)
switch(_chr)
case ' ':
//_encoded.Append("%20");
_encoded.Append("+"); // Trying to match the output of the .Net Core TextEncoder.Encode()
break;
case '!':
_encoded.Append("%21");
break;
case '"':
_encoded.Append("%22");
break;
case '#':
_encoded.Append("%23");
break;
case '$':
_encoded.Append("%24");
break;
case '%':
_encoded.Append("%25");
break;
case '&':
_encoded.Append("%26");
break;
case '-':
_encoded.Append("%2D");
break;
case '/':
_encoded.Append("%2F");
break;
case ':':
_encoded.Append("%3A");
break;
default:
_encoded.Append(_chr);
break;
return _encoded.ToString();
Thank you for sharing,
