Can someone please explain me how can i get the list of all netduino devices connected on local network. We use netduino 3 ethernet edition.
The Netduino devices have the MAC address label on the underside so you can identify specific units and the MAC addresses are pretty easy to spot in a sorted list as they come from a fairly small range 5C-86-4A…-
On a Windows box from a command prompt you could run the ARP command and get a list of the devices the local LAN (assuming you have set the MAC addresses if has been cleared by a device update). ARP is available on other platforms as well as part of TCP/IP packaged utilitiess.
