Help with SSD1608 / 2.13" Adafruit e-ink
I have got the e-ink display from Adafruit which I have wired and tried to run a sample application but the screen does not react.
wiring:
source: Class Ssd1608 | Meadow.Foundation API website
SSD1608 Meadow Pin
BUSY D15
RST D14
DC D13
ECS D12
SCK SCK
MISO MOSI
GND GND
VIN 3V3
    public class MeadowApp : App<F7FeatherV1>
        private MicroGraphics graphics;
        public override Task Initialize()
            Resolver.Log.Info("Initialize...");
            var display = new Ssd1608(spiBus: Device.CreateSpiBus(),
                chipSelectPin: Device.Pins.D12,
                dcPin: Device.Pins.D13,
                resetPin: Device.Pins.D14,
                busyPin: Device.Pins.D15,
                width: 250,
                height: 122);
            graphics = new MicroGraphics(display);
            return Task.CompletedTask;
        public override Task Run()
            try
                graphics.DrawRectangle(10, 10, 20, 20, Meadow.Foundation.Color.Black);
                graphics.Show();
            catch (System.Exception)
                throw;
in the debug, it gets stuck on graphics.Show() line, and nothing happens on the screen.
and then how do I further investigate what is wrong?
Hi @tridy,
Sorry for the late response. I took a look at this sample, and I found a wiring mistake: you want to connect the 3v3 pin on the e-paper with the 3v3 source on the Meadow. I did that small change and I saw my screen updating.
Try that and let me know if it works,
Jorge
Thanks! Well, at this point, there is something wrong with my F7, I am not able to do anything with it.
If I manage to revive it, I will give it a try with 3v3 to 3v3.
