I have a Netduino Plus and I decided to update its Firmware. I erased the old firmware v4.1.1.0 (By placing a wire between the 3.3 volt and the gold pad) but when I try to deploy the new Firmware 4.2.0.1 I can’t because MFDeploy does not see the Netduino. The led by digital pin 1 stays on. Can someone help me. I also tried your new updater and it also does not see the device.
The new updater is designed for use with the Netduino Plus 2/3/Wifi as they are built using the STM32 microcontroller and so this will not work with the original Netduino Plus as that is an Atmel chip.
Thank you for the assist. Using that I erased the 4.1 version of the firmware and updated it to 4.2.
I did this through SAM-BA and then MFDeploy 4.2, but it looks like I lost my network capability even though through MFDeploy I set up the Network with the MAC address and setting DHCP enabled.
I just noticed that using SAM-BA and the MFDeploy This will give you 128KB of Flash and 60KB of RAM–but will remove the lwIP networking feature.
Now I do have an issue though with the Netduino 4.2 SDK and 4.2 firmware I can’t get my one-wire device to work. I was previously using an experimental firmware for 4.1 from CW.NETMF.Hardware for the DS18B20 temperature probe but it will no longer work.
I’ve been trying to use the Microsoft.SPOT.Hardware.OneWire protocol but whenever I access oneWire.TouchReset() or oneWire.FindAllDevices() I get the following error System.NotSupportedException. I am using your 4.2.0.1 firmware for the Netduino Plus V1.
To Install SAM-BA 2.15, I reset my Netduino Plus (by pressing 3v3 and gold squre near io0), َAfter that, when I do connect my Netduino Plus 2 board to PC via USB cable its not showing in the device manager. Please help me.
