I am trying to get the I2c to work using a Adafruit FT232H in a meadow Version 1.3.4.environment.
It is a Windows Application.
Can anyone confirm that it works?
This is the code I’m trying to use:
_expander = new Ft232h();
bus = _expander.CreateI2cBus(_expander.Pins.D0, _expander.Pins.D1, Meadow.Hardware.I2cBusSpeed.Standard);
var Sensor = new Mpr121(bus, 0x5A, 100);
Sensor.ChannelStatusesChanged += Sensor_ChannelStatusesChanged;
Very simple.
The creation of the Mrp121 objects takes a very long time. No exceptions of any kind are thrown.
And the event never gets thrown after the initialization.
Also the same code works when connected to meadow.
Connection an RGB Led to the ft232 works just fine. It just seems like the i2c implementation is not working. Or Im missing something.
Any help or suggestion would be appreciated.
