Just received the meadow F7v2, I’ve installed the latest FW via Zadig (v6.1.7600.16385),
I’ve created new Medow project in VS2019, pressed deploy on the project, and all i get is steady blue led on the meadow board, and "Launching application… "message in visual studio,
Hi! Hopefully you haven’t been beating your head against the wall for too long. I had the same issue. In the build one thing that tipped me off was it was unable to find mono. By running meadow mono update rt in the cli I was able to get mono onto the board, and then meadow mono enable to start mono. After that it gave errors about missing system.dll and a few others, so I deployed again and am up and running. Hopefully this helps!
Is there a doc for flashing firmware? I am having trouble with the ESP2 flash process and would like to see if it’s the main firmware causing problems. I can do a flash OS fine, but it fails on the last step downloading MeadowComms.bin to the ESP2 chip
Hi Ben,
Thanks for responding,
I got help from someone in “Public Slack - Wildernesslabs”,
I had to update to the latest OS 0.6.0.0 through windows Powershell and that solved my issue.
