Firing code block for specific amount of time?
N3wifi
Anyone have suggestions on how to fire a code block for only a certain amount of time after button press interrupt? Not real familiar with Micro Framework, in the past i used to achieve this by adding the timer object and wrapping code to be repeated in the event handler Timer.Tick() and run for the specified Timer.Interval. ie.
Timer TimerDuration =  new Timer();
TimerDuration.interval = 20000;
TimerDuration.Enabled = True;
Want to fire the Handler after a button interrupt port.
Private void TimerDuration_Tick(object sender, EventArgs e)
          //My code that i want to run for the specified amount of time!
Not sure the best way to implement this in the Micro Framework, or maybe there’s a better way.
Any help is appreciated.
Timers exist in NETMF, check out this post from back in 2013.
That’s what i was looking for, thank you.
