HI
I’ve been hitting this problem where the Meadow can’t be found. I updated the drive to WinUSB. Looking at the devices in windows I can see the Meadow or ST there isn’t a COM port associated. I did try USB driver called “USB Serial” which does seem to work to get the meadow to have a COM port.
Meadow list port will show the port (sometimes) but when I try a “device info” or any command it fails with a “Failed to connect”
Oddly flash os seems to work most times
I’ve tried this on 2 different PCs (Win10 20H2) with both a v1 and v2 board.
meadow list ports
Found Meadow: COM3
Done!
meadow device info
Connecting to Meadow on COM3
Failed to connect to Meadow on COM3
System.Exception: Device not ready after 00:01:00s
at Meadow.CLI.Core.Devices.MeadowSerialDevice.InitializeAsync(CancellationToken cancellationToken) in D:\a\1\s\Meadow.CLI.Core\Devices\MeadowSerialDevice.cs:line 98
at Meadow.CLI.Core.DeviceManagement.MeadowDeviceManager.GetMeadowForSerialPort(String serialPort, Boolean verbose, ILogger logger) in D:\a\1\s\Meadow.CLI.Core\DeviceManagement\MeadowDeviceManager.cs:line 58
ERROR
