Connection Refused Issue with Netduino 3 Ethernet
I am having an issue with receiving socket connection on my Netduino 3 Ethernet; “Connection Refused”. My code has been used in the past successfully on a Netduino 2 Plus but does not work on this newer board. Currently my code is blocking at the listening socket Accept call; waiting for a connection. I have my board configured for a static IP and the code is the following for accepting a socket connection. Any help would be appreciated.
try
            _listeningSocket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
             IPEndPoint ipEndPoint = new IPEndPoint(IPAddress.Any, this.Port);
            _listeningSocket.Bind(ipEndPoint);
            _listeningSocket.Listen(1);
                _sessionSocket = _listeningSocket.Accept();
                if (_sessionSocket != null)
                    if (_sessionSocket.Poll(-1, SelectMode.SelectRead))
                        objWebSession = new WebSession(_sessionSocket, this);
                        WebSessions.Add(objWebSession);
                        Debug.Print("Web Session Created");
                        DebugInfo.PrintDebugInfo("Web Session Created");
                        objWebSession.Start();
                foreach (WebSession objWebSessionItem in WebSessions)
                    if (objWebSessionItem != null)
                        if (objWebSessionItem._Completed == true)
                            WebSessions.Remove(objWebSessionItem);
                            Debug.Print("Remove Web Session");
        catch( Exception ex )
            Debug.Print("Web Server Exception Error" + ex.Message);
            DebugInfo.PrintDebugInfo("Web Server Exception Error" + ex.Message);
