Esp32Events [char]
Esp32Requests [char]
IncomingEvents [char]
Meadow successfully deleted '/meadow0/meadow.log'
Meadow successfully deleted '/meadow0/dns.conf'
Meadow successfully deleted '/meadow0/Meadow.OS.Runtime.bin'
Mono is disabled
Mono has been enabled - restarting Meadow
Mono will not start - the following file is missing: App.exe
Mono is enabled
Have tried the mono update but did not solve it.
In another app, run after the attempt above, that works I get:
File 90% downloaded
Download of 'System.pdb' success (checksums calculated:0x476ACEBB, expected:0x476ACEBB)
Mono is disabled
Meadow successfully started MONO
Mono is enabled
Initializing OS...
I think that issue should have been resolved in the 1.3.4 release which went out this week.
Can you please confirm the OS version number.
Updated now get to:
Esp32Events [char]
Mono is disabled
Mono is enabled
Doesn’t progress to call Initialize().
Then crashes Visual Studio after about 1 minute!
Repeated this a few times.
OK 2xMy Bads
Runs now but think I’ve got a SAS problem.
Amqp.AmqpException: ‘Sasl negotiation failed with code Sys.’
All good.
Latest problem was that the SAS token needed updating. Worth noting that they are, as I understand it, temporary???
“Tokens typically are valid for 12 hours (unless set to another value during registration).” From the command line
az iot hub generate-sas-token --help
Arguments
--device-id -d : Target Device.
--du --duration : Valid token duration in seconds. Default: 3600.
Looks like default duration is only 1hr here.
Also ,it is concerning that the sample apps required an un-noted OS version.
