Cannot initialize the Relay Object
I have a little project that I am working on using the Maple Web Server. I followed the instructions for controlling a servo through the web server and it works great. Next I tried to add a relay switch and now it just hangs during initialization of the relay. Here is the code I have to initialize the relay in the MeadowApp.cs class:
RelayController.Relay.Initialize(Device, Device.Pins.D02);
Here is the RelayController class:
using Meadow.Devices;
using Meadow.Foundation.Relays;
using Meadow.Hardware;
namespace ConnectedServo.Meadow
    public class RelayController
        Relay relay;
        protected bool initialized = false;
        public static RelayController Relay { get; private set; }
        private RelayController() { }
        static RelayController()
        public void Initialize(IMeadowDevice device, IPin PwmPin)
            if (initialized)
                return;
            relay = new Relay(device.CreateDigitalOutputPort(PwmPin));
            relay.IsOn = true;
            relay.IsOn = false;
            initialized = true;
        public void OpenRelay()
            relay.IsOn = true;
        public void CloseRelay()
            relay.IsOn = false;
It just hangs in a loop on the relay=new Relay(device.CreateDigitalOutputPort(PwmPin)); line. It will execute the line then jump to the top of the loop. Any help is appreciated.
John
We just released RC-1, can you try with the new build, please? Wilderness Labs Developer Portal
I just did the update, but now the WifiAdapter.Connect is gone. I looked through the docs for the new method of connecting to WIFI and I can’t find it. How do you initialize the WIFI under the new Update?
Okay I got this fixed. But trying to debug I get this pop up
I have updated the code to the new version. Here is my updated MeadowApp.cs file:
 public class MeadowApp : App<F7FeatherV1>
        MapleServer mapleServer;
        public MeadowApp()
            Initialize().Wait();
            mapleServer.Start();
        public override Task Run()
            return base.Run();
        public override  Task Initialize()
            var onboardLed = new RgbPwmLed(device: Device,
                redPwmPin: Device.Pins.OnboardLedRed,
                greenPwmPin: Device.Pins.OnboardLedGreen,
                bluePwmPin: Device.Pins.OnboardLedBlue);
            onboardLed.SetColor(Color.Red);
            ServoController.Current.Initialize(Device, Device.Pins.D10);
            onboardLed.SetColor(Color.Blue);
            var result = SetupWiFi();
            if(result.Result == true)
                onboardLed.SetColor(Color.Green);
            else
            return base.Initialize();
        private async Task<bool> SetupWiFi()
            var wifi = Device.NetworkAdapters.Primary<IWiFiNetworkAdapter>();
            wifi.NetworkConnected += WiFiAdapter_NetworkConnected;
            ScanForAccessPoints(wifi);
            Console.WriteLine($"Connecting to WiFi Network {Secrets.WIFI_NAME}");
            var connectionResult = await wifi.Connect(Secrets.WIFI_NAME, Secrets.WIFI_PASSWORD, TimeSpan.FromSeconds(45));
            if (connectionResult.ConnectionStatus != ConnectionStatus.Success)
                Console.WriteLine($"Cannot connect to network: {connectionResult.ConnectionStatus}");
                return false;
            else
                mapleServer = new MapleServer(wifi.IpAddress, 5417, true);
                DisplayNetworkInformation();
                return true;
        private void DisplayNetworkInformation()
            NetworkInterface[] adapters = NetworkInterface.GetAllNetworkInterfaces();
            if (adapters.Length == 0)
                Console.WriteLine("No adapters available.");
            foreach (NetworkInterface adapter in adapters)
                IPInterfaceProperties properties = adapter.GetIPProperties();
                Console.WriteLine();
                Console.WriteLine(adapter.Description);
                Console.WriteLine(String.Empty.PadLeft(adapter.Description.Length, '='));
                Console.WriteLine($"  Adapter name: {adapter.Name}");
                Console.WriteLine($"  Interface type .......................... : {adapter.NetworkInterfaceType}");
                Console.WriteLine($"  Physical Address ........................ : {adapter.GetPhysicalAddress().ToString()}");
                Console.WriteLine($"  Operational status ...................... : {adapter.OperationalStatus}");
                string versions = String.Empty;
                if (adapter.Supports(NetworkInterfaceComponent.IPv4))
                    versions = "IPv4";
                if (adapter.Supports(NetworkInterfaceComponent.IPv6))
                    if (versions.Length > 0)
                        versions += " ";
                    versions += "IPv6";
                Console.WriteLine($"  IP version .............................. : {versions}");
                    IPv4InterfaceProperties ipv4 = properties.GetIPv4Properties();
                    Console.WriteLine("  MTU ..................................... : {0}", ipv4.Mtu);
                if ((adapter.NetworkInterfaceType == NetworkInterfaceType.Wireless80211) || (adapter.NetworkInterfaceType == NetworkInterfaceType.Ethernet))
                    foreach (UnicastIPAddressInformation ip in adapter.GetIPProperties().UnicastAddresses)
                        if (ip.Address.AddressFamily == System.Net.Sockets.AddressFamily.InterNetwork)
                            Console.WriteLine($"  IP address .............................. : {ip.Address.ToString()}");
                            Console.WriteLine($"  Subnet mask ............................. : {ip.IPv4Mask.ToString()}");
        private async Task ScanForAccessPoints(IWiFiNetworkAdapter wifi)
            Console.WriteLine("Getting list of access points.");
            var networks = await wifi.Scan(TimeSpan.FromSeconds(60));
            if (networks.Count > 0)
                Console.WriteLine("|-------------------------------------------------------------|---------|");
                Console.WriteLine("|         Network Name             | RSSI |       BSSID       | Channel |");
                foreach (WifiNetwork accessPoint in networks)
                    Console.WriteLine($"| {accessPoint.Ssid,-32} | {accessPoint.SignalDbStrength,4} | {accessPoint.Bssid,17} |   {accessPoint.ChannelCenterFrequency,3}   |");
            else
                Console.WriteLine($"No access points detected.");
        private void WiFiAdapter_NetworkConnected(object sender, EventArgs args)
            Console.WriteLine("Connection request Complete...");
I get this error while running it:
Launching application…
[10/27/2022 3:30:26 PM] Meadow StdOut: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.NullReferenceException: Object reference not set to an instance of an object.
at MapleWithServoAndRelay.MeadowApp.Initialize () [0x00083] in <1133e8c17183465087ee745f33520b6e>:0
at MapleWithServoAndRelay.MeadowApp…ctor () [0x00008] in <1133e8c17183465087ee745f33[10/27/2022 3:30:26 PM] Meadow StdOut: 20b6e>:0
at (wrapper managed-to-native) System.Reflection.RuntimeConstructorInfo.InternalInvoke(System.Reflection.RuntimeConstructorInfo,object,object[],System.Exception&)
at System.Reflection.RuntimeConstructorInfo.InternalInvoke (System.Object obj, System.Object[] parameters, System.Boolean wrapExceptions) [0x00005] in <77563d7372d948198f425b41a9b84c90>:0
— End of inn[10/27/2022 3:30:26 PM] Meadow StdOut: r exception stack trace —
at System.Reflection.RuntimeConstructorInfo.InternalInvoke (System.Object obj, System.Object[] parameters, System.Boolean wrapExceptions) [0x0001a] in <77563d7372d948198f425b41a9b84c90>:0
at System.RuntimeType.CreateInstanceMono (System.Boolean nonPublic, System.Boolean wrapExceptions) [0x00095] in <77563d7372d948198f425b41a9b84c90>:0
at System.[10/27/2022 3:30:26 PM] Meadow StdOut: untimeType.CreateInstanceSlow (System.Boolean publicOnly, System.Boolean wrapExceptions, System.Boolean skipCheckThis, System.Boolean fillCache) [0x00009] in <77563d7372d948198f425b41a9b84c90>:0
at System.RuntimeType.CreateInstanceDefaultCtor (System.Boolean publicOnly, System.Boolean skipCheckThis, System.Boolean fillCache, System.Boolean wrapExceptions, System.Threading.Stack[10/27/2022 3:30:26 PM] Meadow StdOut: rawlMark& stackMark) [0x00027] in <77563d7372d948198f425b41a9b84c90>:0
at System.Activator.CreateInstance (System.Type type, System.Boolean nonPublic, System.Boolean wrapExceptions) [0x00020] in <77563d7372d948198f425b41a9b84c90>:0
at System.Activator.CreateInstance (System.Type type, System.Boolean nonPublic) [0x00000] in <77563d7372d948198f425b41a9b84c90>:0
at Meadow.Me[10/27/2022 3:30:26 PM] Meadow StdOut: dowOS.Initialize () [0x000e8] in :0
[10/27/2022 3:30:26 PM] Meadow StdOut: ERROR: Device Initialization Failure
[10/27/2022 3:30:26 PM] Meadow StdOut: INFORMATION: CRASH: Meadow will restart in 5 seconds.
It looks like it can’t initialize the relay. Here is the relay class:
        Relay relay;
        public void Initialize(IMeadowDevice device, IPin pin)
            if (initialized){
                return;
            relay = new Relay(device.CreateDigitalOutputPort(pin));
            relay.IsOn = true;
            relay.IsOn = false;
            initialized = true;
            relay.IsOn = true;
            relay.IsOn = false;
Any help would be much appreciated.
