What is the expected way of managing multiple SPI devices with different clock and speed settings? I have MAX31856 breakout connected and working with Meadow with my own driver. Now I’m going to add a second MAX31856. Do I create one SPI bus and share it with those two or do i create two bus instances? They use the same clock settings.
Third device will be a OLED screen also a SPI device but it will use different clock settings and speed.
On arduino or system.io.gpio the clock settings and speed are set on the device side but the Meadow API would imply that you have one SPI bus instance for multiple devices but that wouldn’t allow setting speed and clock settings per device.
