Hi Sir,
I 'm new in this forum.
I am trying to read ds2401 with 1-wire protocol.
Are there any examples where to take the lead?
Thank you
Alex
Hi Sir,
Thank you
Alex
If you are trying to read the temperature I am using the TMP36 here:
This is the class library I wrote is here.
Imports System
Imports Microsoft.SPOT
Imports Microsoft.SPOT.Hardware
Imports SecretLabs.NETMF.Hardware
'Need reference to SecretLabs.NETMF.Hardware.AnalogInput.dll
Imports SecretLabs.NETMF.Hardware.AnalogInput
Imports SecretLabs.NETMF.Hardware.Netduino
Imports Microsoft.VisualBasic.Strings
Private Shared Port As SecretLabs.NETMF.Hardware.AnalogInput
'Changed 12/15/15
'Public Shared TemperatureAdjustment As Integer = 0
Public Shared TemperatureAdjustment As Integer = -2
Public Shared CurrentTemperature As String = String.Empty
Public Shared NewThread As Thread = New Thread(AddressOf PollTemperature)
Public Shared Sub PollTemperature()
While True
GetTemperature()
'5 min.
Thread.Sleep(300000)
End While
End Sub
Public Shared Sub OpenAnalogPort(Optional AnalogInputPin As Integer = 0)
Try
Select Case AnalogInputPin
Case 0
Port = New SecretLabs.NETMF.Hardware.AnalogInput(Pins.GPIO_PIN_A0)
Case 1
Port = New SecretLabs.NETMF.Hardware.AnalogInput(Pins.GPIO_PIN_A1)
Case 2
Port = New SecretLabs.NETMF.Hardware.AnalogInput(Pins.GPIO_PIN_A2)
Case 3
Port = New SecretLabs.NETMF.Hardware.AnalogInput(Pins.GPIO_PIN_A3)
Case 4
Port = New SecretLabs.NETMF.Hardware.AnalogInput(Pins.GPIO_PIN_A4)
Case 5
Port = New SecretLabs.NETMF.Hardware.AnalogInput(Pins.GPIO_PIN_A5)
Case Else
End Select
Catch ex As Exception
Debug.Print("Error in OpenAnalogPort " & AnalogInputPin.ToString & ": " & ex.ToString)
End Try
End Sub
Public Shared Sub GetTemperature()
Try
Dim CurrentValue As Double = 0
Dim CurrentVoltage As Single = 0
Dim Temperature As Single = 0
Dim Fahrenheit As Integer = 0
Dim Degree As String = ChrW(176)
For i = 1 To 20
CurrentValue += Port.Read
Thread.Sleep(10)
Next i
CurrentValue = CurrentValue / 20
CurrentVoltage = CSng(CurrentValue * 3.3)
CurrentVoltage = CurrentVoltage / 1024
Temperature = CSng(CurrentVoltage - 0.5) * 100
Fahrenheit = CInt((Temperature * 1.8) + 32.0) + TemperatureAdjustment
CurrentTemperature = Fahrenheit.ToString
Debug.Print("Error in GetTemperature: " & ex.ToString)
End Try
End Sub
End Class
To use just start the thread:
Tmp36.NewThread.Start()
Now the temperature can be read at any time using this.
Tmp36.CurrentTemperature
I hope this helps
Hi David,
Thanks for replay, but TMP36 is analog sensor.
DS2401 is digital device.
Regards
ALEX
Someone wrote a driver for the DS18B20 a while ago. Discussion is here: http://forums.netduino.com/index.php?/topic/10762-1-wire-ds18b20-programming-errors/
Original code is here: https://www.ghielectronics.com/community/codeshare/entry/438
Could this be reused?
Strange , I read fine ds18b20 with onwire, but no work with ds2401.
There is a sample in comunity?
Regards
Alex
