I just opened my Netduino Go for the first time after it sat on a shelf for several years. The board lights up and visual studio recognizes the board. I downloaded the firmware update utility and chose the “4.3.2.0 Beta 1” for Netduino Go. Now I am getting the below error when I try the Blinky code to blink the onboard led.
The thread ‘’ (0x2) has exited with code 0 (0x0).
Exception thrown: ‘System.ArgumentException’ in Microsoft.SPOT.Hardware.dll
An unhandled exception of type ‘System.ArgumentException’ occurred in Microsoft.SPOT.Hardware.dll
The program ‘[4] Micro Framework application: Managed’ has exited with code 0 (0x0).
Also, here is the code I am trying to run targeting the 4.3 framework:
using System.Net;
using System.Net.Sockets;
using Microsoft.SPOT;
namespace Blinky
public class Program
public static void Main()
// write your code here
OutputPort led = new OutputPort(Pins.ONBOARD_LED, false);
led.Write(true);
Thread.Sleep(250);
led.Write(false);
Thread.Sleep(250);
Another question. If I want to go back to the original firmware how do I do this?
