Hello and back and started looking back where I left off. However I am seeing an issue where the Netdunio is not seen on Windows via VS2015 and support tools. However If I move everything to my Mac Mini then VS and all Mac support tools.
So to be clear when connecting the Netdunio and holding the reset button ONLY the Mac sees the Netdunio. Looking at the Projects Framework tab the USB device is always none.
When you hold the reset button down and connected power to the Netduino then the board enters DfU mode. In this mode the firmware can be updated. In this mode the Windows PC should see the board as an STM device - you can check Device Manager to verify this. In this mode VS will not see the board as a Netduino.
Same problem here, too. At the moment the Netduino 3 doesn’t show up in VB2015. And it doesn’t show up in NetduinoUpdate. Windows Device Manager does see it, both when it’s connected normally, and when connected with the button pressed (having different names). This situation is after I’ve messed around trying to follow every device I’ve found on the Wilderness site about upgrading firmware.
So I believe I’d need some complete reset of the board, a hard reset, a total reflash of the original stuff no matter in what messed state the board is right now.
I was thinking, I do not see a Troubleshooting FAQ. It might be good to create one and as this project continues - we can add detailed fixes and workarounds and might be a quick help resource. I have not helped in a project before but would be willing to spend some time with a FAQ.
We would love for you to help. There is some Troubleshooting documentation available and as will all things I’m sure we can add more stuff to it and make it better. It would be fantastic if you would be willing to contribute.
Perhaps the easiest way to get started is to clone the documentation from Github make some additions / improvements and submit pull requests.
I wish I remembered each step that lead to success and each step that didn’t. It was about deleting the Netduino from Windows device manager and having Netduino being re-installed, not just reinstalling the driver inside the device manager, which only told the latest driver is installed. It was about running the netduinosdk_v5.exe. It was about using zadig-2.4.
I got home tonight and looked at my Device Manger again and instead of seeing Netduino 3 wifi listed - I see just the name as Netduino. I uninstalled, rebooted and re-installed many many times!!! The result is ALWAYS the same - just a Netduino.
Does this mean my Netduino is bad? Since I get exceptions?
