Thanks for the response. No luck yet.
I was able to find where dfu-util is located on my machine and update it with the correct version. That error has gone away. But I am still not getting the Meadow to update.
C:\>meadow flash os
Having trouble putting Meadow in DFU Mode, please press RST button on Meadow and press enter to try again
+Device in DFU Mode, flashing OS
Flashing OS with C:\Users\Trey\AppData\Local\WildernessLabs\Firmware\Meadow.OS.bin
dfu-util 0.10
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2020 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Match vendor ID from file: 0000
Match product ID from file: 0000
Opening DFU capable USB device...
ID 0483:df11
Run-time device DFU version 011a
Claiming USB DFU Interface...
Setting Alternate Setting #0 ...
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 011a
Device returned transfer size 2048
DfuSe interface name: "Internal Flash "
Downloading element to address = 0x08000000, size = 2097152
Erase done.
Download done.
File downloaded successfully
Transitioning to dfuMANIFEST state
Warning: Invalid DFU suffix signature
Device Flashed.
Connecting to Meadow on COM3
An error occurred while attempting to create Meadow
System.IO.FileNotFoundException: Could not find file 'COM3'.
File name: 'COM3'
at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace)
at System.IO.Ports.SerialPort.Open()
at Meadow.CLI.Core.Devices.MeadowSerialDevice.OpenSerialPort(String portName) in D:\a\1\s\Meadow.CLI.Core\Devices\MeadowSerialDevice.cs:line 127
at Meadow.CLI.Core.Devices.MeadowSerialDevice..ctor(String serialPortName, ILogger logger) in D:\a\1\s\Meadow.CLI.Core\Devices\MeadowSerialDevice.cs:line 21
at Meadow.CLI.Core.DeviceManagement.MeadowDeviceManager.<>c__DisplayClass4_0.<GetMeadowForSerialPort>b__0() in D:\a\1\s\Meadow.CLI.Core\DeviceManagement\MeadowDeviceManager.cs:line 38
at System.Threading.Tasks.Task`1.InnerInvoke()
at System.Threading.Tasks.Task.<>c.<.cctor>b__277_0(Object obj)
at System.Threading.ExecutionContext.RunFromThreadPoolDispatchLoop(Thread threadPoolThread, ExecutionContext executionContext, ContextCallback callback, Object state)
--- End of stack trace from previous location ---
at System.Threading.Tasks.Task.ExecuteWithThreadLocal(Task& currentTaskSlot, Thread threadPoolThread)
at Meadow.CLI.Core.DeviceManagement.MeadowDeviceManager.GetMeadowForSerialPort(String serialPort, Boolean verbose, ILogger logger) in D:\a\1\s\Meadow.CLI.Core\DeviceManagement\MeadowDeviceManager.cs:line 47
Meadow StdInfo: MONO won't start, the following file(s) missing: mscorlib.dll, System.Core.dll, System.dll, Meadow.dll, App.exe
Meadow StdInfo: Mono enabled, will run app.exe
Unhandled exception. Failed to connect to Meadow on System.ArgumentNullException: Value cannot be null.
at System.Threading.Monitor.ReliableEnter(Object obj, Boolean& lockTaken)
at Meadow.CLI.Core.Devices.MeadowSerialDevice.Dispose(Boolean disposing) in D:\a\1\s\Meadow.CLI.Core\Devices\MeadowSerialDevice.cs:line 41
at Meadow.CLI.Core.Devices.MeadowLocalDevice.Finalize() in D:\a\1\s\Meadow.CLI.Core\Devices\MeadowLocalDevice.cs:line 387
COM3
System.Exception: Device not ready after 00:01:00s
at Meadow.CLI.Core.Devices.MeadowSerialDevice.InitializeAsync(CancellationToken cancellationToken) in D:\a\1\s\Meadow.CLI.Core\Devices\MeadowSerialDevice.cs:line 105
at Meadow.CLI.Core.DeviceManagement.MeadowDeviceManager.GetMeadowForSerialPort(String serialPort, Boolean verbose, ILogger logger) in D:\a\1\s\Meadow.CLI.Core\DeviceManagement\MeadowDeviceManager.cs:line 57
ERROR
at Meadow.CLI.Core.Devices.MeadowSerialDevice.InitializeAsync(CancellationToken cancellationToken) in D:\a\1\s\Meadow.CLI.Core\Devices\MeadowSerialDevice.cs:105
at Meadow.CLI.Core.DeviceManagement.MeadowDeviceManager.GetMeadowForSerialPort(String serialPort, Boolean verbose, ILogger logger) in D:\a\1\s\Meadow.CLI.Core\DeviceManagement\MeadowDeviceManager.cs:57
at Meadow.CLI.Core.DeviceManagement.MeadowDeviceManager.FindMeadowBySerialNumber(String serialNumber, ILogger logger, Int32 maxAttempts, CancellationToken cancellationToken) in D:\a\1\s\Meadow.CLI.Core\DeviceManagement\MeadowDeviceManager.cs:137
at Meadow.CLI.Commands.DeviceManagement.FlashOsCommand.ExecuteAsync(IConsole console) in D:\a\1\s\Meadow.CLI\Commands\DeviceManagement\FlashOsCommand.cs:59
at CliFx.CliApplication.RunAsync(ApplicationSchema applicationSchema, CommandInput commandInput) in \home\runner\work\CliFx\CliFx\CliFx\CliApplication.cs:147
at CliFx.CliApplication.RunAsync(IReadOnlyList`1 commandLineArguments, IReadOnlyDictionary`2 environmentVariables) in \home\runner\work\CliFx\CliFx\CliFx\CliApplication.cs:191
Done!
Also the meadow device info isn’t working for me and is returning an exception it cannot find COM3. But, I can do a meadow flash os immediately after this (without unplugging or anything) and it will find it on COM3 to update (and still fail.)
C:\>meadow device info
Connecting to Meadow on 3
System.ArgumentException: The given port name (3) does not resolve to a valid serial port. (Parameter 'portName')
Failed to connect to Meadow on 3
ERROR
at Meadow.CLI.Core.Devices.MeadowSerialDevice.OpenSerialPort(String portName) in D:\a\1\s\Meadow.CLI.Core\Devices\MeadowSerialDevice.cs:127
at Meadow.CLI.Core.Devices.MeadowSerialDevice..ctor(String serialPortName, ILogger logger) in D:\a\1\s\Meadow.CLI.Core\Devices\MeadowSerialDevice.cs:21
at Meadow.CLI.Core.DeviceManagement.MeadowDeviceManager.<>c__DisplayClass4_0.<GetMeadowForSerialPort>b__0() in D:\a\1\s\Meadow.CLI.Core\DeviceManagement\MeadowDeviceManager.cs:38
at Meadow.CLI.Core.DeviceManagement.MeadowDeviceManager.GetMeadowForSerialPort(String serialPort, Boolean verbose, ILogger logger) in D:\a\1\s\Meadow.CLI.Core\DeviceManagement\MeadowDeviceManager.cs:47
at Meadow.CLI.Commands.MeadowSerialCommand.ExecuteAsync(IConsole console) in D:\a\1\s\Meadow.CLI\Commands\MeadowSerialCommand.cs:63
at Meadow.CLI.Commands.DeviceManagement.GetDeviceInfoCommand.ExecuteAsync(IConsole console) in D:\a\1\s\Meadow.CLI\Commands\DeviceManagement\GetDeviceInfoCommand.cs:23
Done!
