Guys I have attempted many times to get this to build but it is not. I think that msbuild is not executing but do not see why. here is my output but it executes in 2s not 10m.
C:\net4_4_0>call setenv_gcc 4.9.3 “C:\netmf\gcc_4_9_3” call cd Solutions\STM32F411NUCLEO msbuild /t:build /p:flavor=release;memory=flash /fl call C:\WINDOWS\explorer.exe “C:\netmf\netmf4_4_0\BuildOutput\THUMB2FP\GCC4.9\le\FLASH\release\STM32F411NUCLEO\bin”
Compiler: GCC 4.9.3 C:\netmf\gcc_4_9_3
setting vars for GCC compiler GCC4.9.3
It failed to build - i am not familiar with this message… looking online is pointing nuget. is this the floating point issue? If I open the project in vsd2015 it fails to load the project.
C:\net4_4_0\tools\Targets\Microsoft.SPOT.Build.Targets(929,5): error MSB4062: The “Microsoft.SPOT.Tasks.GenerateTinyRes
ource” task could not be loaded from the assembly C:\net4_4_0\BuildOutput\Public\Release\Server\dll\Microsoft.SPOT.Task
s.dll. Could not load file or assembly ‘file:///C:\net4_4_0\BuildOutput\Public\Release\Server\dll\Microsoft.SPOT.Tasks.
dll’ or one of its dependencies. The system cannot find the file specified. Confirm that the declaration is
correct, that the assembly and all its dependencies are available, and that the task contains a public class that implements Microsoft.Build.Framework.ITask. [C:\net4_4_0\Framework\Subset_of_CorLib\SpotCorLib.csproj]
Build fails still - looks like files are missing or path is wrong? Earlier I was trying moving the folder but it does not matter.
Cannot attach the build output file but here is a snippet…
WixLibSpotBuild -> C:\net4_4_0\BuildOutput\Public\release\Server\dll\Microsoft.SPOT.WiX.dll
Done Building Project “C:\netmf\net4_4_0\Framework\Tools\WiXLib\WixLibSpotBuild.csproj” (Build target(s)).
Project “C:\netmf\net4_4_0\Framework\Tools\BuildTasks.dirproj” (5) is building “C:\netmf\net4_4_0\Framework\Tools\BuildTasksInternal\BuildSigner\BuildSignerSpotBuild.csproj” (7) on node 1 (Build target(s)).
StartBuild:
Building…C:\netmf\net4_4_0\Framework\Tools\BuildTasksInternal\BuildSigner\BuildSignerSpotBuild.csproj;
ResolveAssemblyReferences:
Primary reference “CODESIGN.Submitter”.
C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.Common.CurrentVersion.targets(1820,5): warning MSB3245: Could not resolve this reference. Could not locate the assembly “CODESIGN.Submitter”. Check to make sure the assembly exists on disk. If this reference is required by your code, you may get compilation errors. [C:\netmf\net4_4_0\Framework\Tools\BuildTasksInternal\BuildSigner\BuildSignerSpotBuild.csproj]
For SearchPath “{HintPathFromItem}”.
Considered “C:\netmf\tools\x86\CODESIGN\CODESIGN.Submitter.dll”, but it didn’t exist.
For SearchPath “{TargetFrameworkDirectory}”.
Considered “C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework.NETFramework\v4.5\CODESIGN.Submitter.winmd”, but it didn’t exist.
Considered “C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework.NETFramework\v4.5\CODESIGN.Submitter.dll”, but it didn’t exist.
Considered “C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework.NETFramework\v4.5\CODESIGN.Submitter.exe”, but it didn’t exist.
Considered “C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework.NETFramework\v4.5\Facades\CODESIGN.Submitter.winmd”, but it didn’t exist.
Considered “C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework.NETFramework\v4.5\Facades\CODESIGN.Submitter.dll”, but it didn’t exist.
Considered “C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework.NETFramework\v4.5\Facades\CODESIGN.Submitter.exe”, but it didn’t exist.
For SearchPath “{AssemblyFolders}”.
Considered “C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework\v3.5\CODESIGN.Submitter.winmd”, but it didn’t exist.
Considered “C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework\v3.5\CODESIGN.Submitter.dll”, but it didn’t exist.
Considered “C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework\v3.5\CODESIGN.Submitter.exe”, but it didn’t exist.
For SearchPath “{GAC}”.
Considered “CODESIGN.Submitter”, which was not found in the GAC.
For SearchPath “{RawFileName}”.
Considered treating “CODESIGN.Submitter, Version=4.1.0.0, Culture=neutral, PublicKeyToken=3d8252bd1272440d, processorArchitecture=MSIL” as a file name, but it didn’t exist.
Ok I started over and think the steps are off …
Step #8 and #9 have wrong paths, I think.
Also when I unzip the netmf-interpreter should the folder exist? C:\netmf\netmf4_4_0\netmf-interpreter-dev?
This is why I started moving folder(s) around since it seerms paths are wrong.
Step 8
Download the CMSIS tools (rename the file extension “.pack” to “.zip” and unzip them in the c:\net4_4_0
Should read C:\netfm\netfm4_4_0 and has been corrected
Step 9
Create a batch file in the c:\net4_4_0 should be
Still not building …
Is there a time table to a release of this framework?
Between steps 8 & 9 there should there be a step to run powershell script: ./Install-CMSIS,ps1?
How about ./Install-BinTools.ps1?
What about Marks issue “By default, the ARM compiler needed the floating point libraries moving to the right place.” ?
“C:\netmf\netmf4_4_0\Solutions\STM32F411NUCLEO\dotnetmf.proj” (build target) (1) →
“C:\netmf\netmf4_4_0\Framework\Tools\CreateCLRDefines.proj” (Build target) (12:176) →
(BuildClrDefines target) →
C:\netmf\netmf4_4_0\Framework\Tools\CreateCLRDefines.proj(12,5): error MSB4062: The “Microsoft.SPOT.Tasks.Internal.Ge
nerateCLRDefines” task could not be loaded from the assembly C:\netmf\netmf4_4_0\BuildOutput\Public\Release\Server\dll
Microsoft.SPOT.Tasks.Internal.dll. Could not load file or assembly ‘file:///C:\netmf\netmf4_4_0\BuildOutput\Public\Rele
ase\Server\dll\Microsoft.SPOT.Tasks.Internal.dll’ or one of its dependencies. The system cannot find the file specified
. Confirm that the declaration is correct, that the assembly and all its dependencies are available, and th
I’m sorry that you folks are struggling with this. For what it’s worth, we’re in flight with a significant simplification of this, and a port of 4.4 to Netduino.
