If you are not in a hurry and just want to get to grips with the build process then I would have a look at this thread on building NETMF 4.4. The build process discussed in that thread uses GCC so while the objects produced are a little larger than Keil it has the benefit that it is free.
As Bryan mentioned, there is work on going to try and simplify the process.
Regards,
Mark
