I am trying to get Azure IOT HUB ‘calling direct methods’ to work on Netduino.
I think I need to use AMQP for this since the C# iot SDK (Microsoft.Azure.Devices.Client.Http.NetMF_43) only support simple D2C and C2D events.
When doing a simple AMQP C2D receive using the following code, all works fine
static private void ReceiveCommands()
string entity = Fx.Format("/devices/{0}/messages/deviceBound", DEVICE_ID);
ReceiverLink receiveLink = new ReceiverLink(session, "receive-link", entity);
Message received = receiveLink.Receive();
while (received != null)
if (received != null)
receiveLink.Accept(received);
receiveLink.Close();
But, when replacing the receive link to amqps://{hostname}:5671/devices/{deviceId}/methods/deviceBound as per instructions in https://docs.microsoft.com/en-us/azure/iot-hub/iot-hub-devguide-direct-methods
string entity = Fx.Format("/devices/{0}/methods/deviceBound", DEVICE_ID); // This is the change!!!!
I get the following error message when executing ‘receiveLink.Receive()’
The link address ‘amqps://XXX.azure-devices.net:5671/devices/XXXXXX/methods/deviceBound’ did not match any of the expected formats.
For some reason the IOT HUB I’ve created also only shows two endpoint
messages/servicebound/feedback
messages/events
Could this be the problem? In that case, how does one add more endpoints, especially one that handles ‘methods’?
Also, can anybody please help me with some sample code where AMQP is used to receive direct methods on the device?
It shall be much appreciated.
