At present,my Netduino 3 is in the DFU bootloader mode.How can i make that in a normal programming mode.
Anyone please help,very urgent!
DFU mode is activated when the board is plugged into the computer and the reset button is pressed as the USB cable is plugged into the board.
Unplug the board and then reconnect it to the computer being careful not to press the reset button as you connect the USB cable.
If the above does not work then follow the instructions on the firmware update page.
