Pinging until I get an API response
Hello User,
I am trying to make a system that has a interface where you can interact with my Meadow. I had the idea to create an Api call (on the meadow ) whenever you press a button. So for instance, when I click on a button called “Start”, my Meadow recieves a Json object from an Api call.
So I started thinking and I thought “In order for my Meadow to know if someone clicked the button, it needs to be searching for a Api response” So if it get’s a response of a json object, than store the object in a variable. If not, keep on searching. So I created a while loop that keeps on searching till it has success. Something like this:
public MeadowApp()
            Initialize().Wait();
            var service = new Service();
                using (var result = service.GetData())
                    if (result.Result.ClientIp == "123") // I am using client ip for example
                        Console.WriteLine("Json found!");
                        break;
                    result.Dispose();
                    Console.WriteLine("Nothing found yet...");
But after a while, maybe 2/3 minuts, I get one of these errors:
Or
Could not allocate 8192 bytes
So the infinite loop idea wasn’t a really good think I guess. The Meadow memory couldn’t keep up even though I dispose the result.
But I had a plan B, using a Maple server. The Maple server is pinging every 2 seconds and that’s something I need. So when I click the “Start” button, the maple server starts and when I get a Json result, the Maple server stops. I started creating this code and again I came up with the exact same error or this error:
You probably have a broken mono install. if you see other errors or faults after this message they are probably related and you need to fix your mono install first.
This is the code I have:
public MeadowApp()
            Console.WriteLine("Starting initialization...");
            Console.WriteLine("Initialization Completed");
            server.Start();
            if (server.Running)
                onboardLed.StartPulse(Color.Green);
            else
                onboardLed.StartPulse(Color.Red);
        async Task Initialize()
            onboardLed = new RgbPwmLed(device: Device,
                redPwmPin: Device.Pins.OnboardLedRed,
                greenPwmPin: Device.Pins.OnboardLedGreen,
                bluePwmPin: Device.Pins.OnboardLedBlue,
                3.3f, 3.3f, 3.3f,
                Meadow.Peripherals.Leds.IRgbLed.CommonType.CommonAnode);
            // initialize the wifi adpater
            if (!Device.InitWiFiAdapter().Result)
                throw new Exception("Error: Kan de WiFi adapter niet vinden.");
            // connnect to the wifi network.
            Console.WriteLine($"Connecting to Wifi...");
            var connectionResult = await Device.WiFiAdapter.Connect(Secrets.WIFI_NAME, Secrets.WIFI_PASSWORD);
            if (connectionResult.ConnectionStatus != ConnectionStatus.Success)
                throw new Exception($"Error: Kan niet connecten met het WiFi netwerk: {connectionResult.ConnectionStatus}");
            Console.WriteLine("Connected!");
            // create our maple web server
            Console.WriteLine("Starting Maple server...");
            onboardLed.StartPulse(Color.Yellow);
            try
                server = new Meadow.Foundation.Web.Maple.Server.MapleServer(
                    Device.WiFiAdapter.IpAddress,
                    advertise: true,
                    processMode: RequestProcessMode.Parallel
            catch (OutOfMemoryException e)
                Console.WriteLine("Terminating application unexpectedly...");
                Environment.FailFast(String.Format("Out of Memory: {0}",
                    e.Message));
And DataRequestHandler:
public async void Hello()
            var serverUri = "http://worldtimeapi.org/api/timezone/Europe/Amsterdam";
            var body = @"";
            using (HttpClient client = new HttpClient())
                client.Timeout = new TimeSpan(0, 1, 0);
                var request = new HttpRequestMessage
                    Method = HttpMethod.Get,
                    RequestUri = new Uri(serverUri),
                    Content = new StringContent(body, Encoding.UTF8, RestSharp.Serialization.ContentType.Json),
                Console.WriteLine("Adding headers");
                /*client.DefaultRequestHeaders.Authorization =
                    new AuthenticationHeaderValue("Bearer", Token.access_token);*/
                    .Accept
                    .Add(new MediaTypeWithQualityHeaderValue("application/json")); // Accept header
                Console.WriteLine("Done!");
                Console.WriteLine("Waiting for response..."); // The code stops here
                HttpResponseMessage response = await client.SendAsync(request).ConfigureAwait(true);
                Console.WriteLine(response.ReasonPhrase + " = ReasonPhrase");
                response.EnsureSuccessStatusCode();
                string json = await response.Content.ReadAsStringAsync();
                obj = JObject.Parse(json);
            this.Context.Response.ContentType = ContentTypes.Application_Json;
            this.Context.Response.StatusCode = 200;
            this.Send(obj).Wait();
After
Console.WriteLine(“Waiting for response…”); // The code stops here
I don’t get any response anymore…
Sorry for the long post and hopefully someone understands what I am saying, I have a sample project that I can upload to Github. If their is any explaination needed, let me know!
