I’m stuck, I have 2 Meadow boards (that I just received a few days ago, and this is my first experience with Meadow) and both boards will not run app.exe using the HelloMeadow Example and OS 0.4.2
I feel like everything is set up correctly. However, I must be missing something.
The following is the Build info…
1>------ Build started: Project: HelloMeadow, Configuration: Debug Any CPU ------
1>HelloMeadow -> C:\Users\Work\source\repos\HelloMeadow\HelloMeadow\bin\Debug\net472\App.exe
2>------ Deploy started: Project: HelloMeadow, Configuration: Debug Any CPU ------
2>[12/16/2020 5:41:07 AM] Deploying to Meadow on COM10…
2>[12/16/2020 5:41:15 AM] Checking files on device (may take several seconds) (00:00:07.8208337 since last.)
2>[12/16/2020 5:41:24 AM] Found App.exe (00:00:09.6133008 since last.)
2>[12/16/2020 5:41:24 AM] Found mscorlib.dll (00:00:00.0000076 since last.)
2>[12/16/2020 5:41:24 AM] Found Meadow.dll (00:00:00.0000040 since last.)
2>[12/16/2020 5:41:24 AM] Found System.dll (00:00:00.0000024 since last.)
2>[12/16/2020 5:41:24 AM] Found Mono.Security.dll (00:00:00.0000022 since last.)
2>[12/16/2020 5:41:24 AM] Found System.Configuration.dll (00:00:00.0000022 since last.)
2>[12/16/2020 5:41:24 AM] Found System.Xml.dll (00:00:00.0000025 since last.)
2>[12/16/2020 5:41:24 AM] Found System.Security.dll (00:00:00.0000022 since last.)
2>[12/16/2020 5:41:24 AM] Found System.Core.dll (00:00:00.0000021 since last.)
2>[12/16/2020 5:41:24 AM] Found System.Numerics.dll (00:00:00.0000076 since last.)
2>[12/16/2020 5:41:24 AM] Found Meadow.Foundation.dll (00:00:00.0000027 since last.)
2>[12/16/2020 5:41:24 AM] Writing App.exe (00:00:00.0668967 since last.)
2>[12/16/2020 5:41:28 AM] Deployment Duration: 00:00:20.9404833 (00:00:03.4371874 since last.)
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
========== Deploy: 1 succeeded, 0 failed, 0 skipped ==========
Launching application…
…Nothing happens on the board
When I close VS2019 for Windows and open PuTTY on the COM Port this is what is there
!Meadow successfully started MONOMono enabled, will run app.exe
When I open a Command Prompt and List Files, this is the Error I get.
C:\Users\Work>meadow --ListFiles
Opening port ‘COM10’
Data: Meadow will not start MONO because it didn’t run correctly last time
Data: Mono enabled, will run app.exe
ID: Meadow by Wilderness Labs, Model: F7Micro, MeadowOS Version: 0.4.2 (Dec 8 2020 10:09:54), Processor: STM32F777IIK6, Processor Id: 2c-00-37-00-0d-51-38-32-37-35-36-30,Serial Number: 306D356D3238, CoProcessor: ESP32, CoProcessor OS Version: 0.4.2.0
Getting list of files
File List:
/meadow0/App.exe
/meadow0/mscorlib.dll
/meadow0/Meadow.dll
/meadow0/System.dll
/meadow0/Mono.Security.dll
/meadow0/System.Configuration.dll
/meadow0/System.Xml.dll
/meadow0/System.Security.dll
/meadow0/System.Core.dll
/meadow0/System.Numerics.dll
/meadow0/Meadow.Foundation.dll
A total of 11 files found
Any thoughts on what I’m missing?
Thanks, Paul
