I know this is probably not a Meadow specific question.
I am trying to use the HttpClient.GetAsync method to get some data from the LUIS.ai API.
This API uses some address like:
https://westeurope.api.cognitive.microsoft.com
If you go to that URL, it’ll give you a 404 not found.
Though if you add the correct path after that url, it will give you a result.
I think the issue lies with the base address returning a 404, because I get an error:
No such host is known
This makes sense if the check is based on a status code for the base url.
pinging the base address using the CMD also doesn’t return any data.
Is there any way to skip this host check?
Thanks in advance!
