im on windows 10\x64 build 1809 and i’ve installed the SDK however my device is not showing up, am i missing something?
Thanks for your reply! i think perhaps my usb cable is to blame, i’ll go get a proper cable and return with my result.
Fixed the issue with a D+\D- cable, thanks.
New issue, i manged to push the test App to the device however when i try to push anything else i get a Timeout Deployment Error. Any Ideas?
Please check below link and see if that can helps.
still happening, so i don’t know.
Problem Resolved it was just a bad unit.
