Any Netduino MQTT samples?
Years ago I believe that I had my Plus 1 working using M2MQTT but that was back in the VS2010 days and I don’t have the code anymore. Now I am trying to get my Plus 2 or Plus 3 Wi-Fi going.
Has anyone used MQTT with the Netduino 3 Wi-Fi? I would be eternally greatful for a sample, I haven’t found anything to get it working so far.
Many thanks.
An old community post points to the existence of some MQTT code for the Netduino on GitHub.
BTW - I have MQTT for Netduino on my list of desirable projects. So much tech, so little time…
This any use to you?
i didn’t that exist
just to update to use latest standard (1.3/1.5) and add security TSL 1.2
this one will be an perfect things.
Thanks Nevyn, I downloaded those samples and any others I could find on github. None have worked out of the box so far. I will get back to beating on it soon and will update if I can get anything working.
